Date/Time: Thu, 19 Nov 2026 11:17:00 +0000
Bitcoin infinite level of depth
View Count: 554
[2024-11-23 21:59:30]
pike409 - Posts: 13
10 days ago i managed to see resting orders up to 160 000 price at bitcoin. I been messing around and now i am limited again to couple of thulsands over and under. i cant remember how i enabled it.
the dom is somehow limited i figured that out but setting the levels to 0 wont unlock the higher levels.
much apprechiated.
Date Time Of Last Edit: 2024-11-23 23:22:01
imageScreenshot_250.png / V - Attached On 2024-11-23 21:53:50 UTC - Size: 19.21 KB - 177 views
[2024-11-25 14:36:22]
The only way to really see a price value that is far away from the current price is to compress the scale, shift it, and then expand again to get close to what you want to see and repeat until you get where you want to be.
[2024-11-25 20:14:38]
pike409 - Posts: 13
I know how the scale works.
Here is an old post where someone had issuses with an infinite level of depth. DOM Graph depth cannot be limited - graph gets swamped out
I would like to unlock the actual infinite levels not only the max.
1400 levels is what i can see now. It is confirmed in the MArket Depth Window.
Alternatively, how can I change the global symbol settings or tick settings or something so that 1400 level would show more price then currently? I only care about the resting orders approximate location. dont need to be accurate.
Thank you.
imageScreenshot_387.png / V - Attached On 2024-11-25 20:08:45 UTC - Size: 33.86 KB - 175 views
[2024-11-25 21:52:30]
1400 levels is all we have available.
