Date/Time: Thu, 19 Nov 2026 11:17:01 +0000
Random wick colors in studies
View Count: 593
| [2024-11-23 13:02:43] |
| User311344 - Posts: 142 |
When chart candles are set to have different color than candle outline all studies using bars start having pretty random wick collors, not coresponding with actual study candle value. Not only Spreadsheet Study (bar) but also core studies as BidAsk Difference bars (screenshoot). Is there any way to have correct wick collors? Date Time Of Last Edit: 2024-11-23 13:03:23
| [2024-11-23 21:38:10] |
| Sierra_Chart Engineering - Posts: 25441 |
This page has full documentation on this subject: Color Settings for Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-23 21:38:19
| [2024-11-25 08:20:49] |
Im well aware of that documentation. But it doesnt explain why there are wrong wick colors on many bars of that built-in study. I attached study settings on the screenshot. Date Time Of Last Edit: 2024-11-25 09:51:22
Private File |
| [2024-11-25 18:09:13] |
| John - SC Support - Posts: 48583 |
Please get us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-25 21:27:28] |
Sure. Thanks! Also a screenshot of my Global Graphics Settings (Color candlestick high-low using outline colors = False). |
Private File Private File |
| [2024-11-28 22:18:34] |
We understand the reason for why you see what you do. The coloring of the High-Low bar is not random. It is based upon the previous close to current close difference. We are going to change that to follow this setting in case of a candlestick: Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
