Date/Time: Thu, 19 Nov 2026 11:25:03 +0000
Trade Activity Log Issues
View Count: 541
| [2024-11-22 19:42:46] |
| User509533 - Posts: 99 |
I traded multiple futures symbols (both long and short) last week. However, under the 'Trade' tab, TAL is displaying either all long or all short trades for a particular symbol, rather than reflecting the actual trades. Interestingly, the issue seems to resolve temporarily if I switch to a longer time window with all symbols and then return to a shorter time window with a specific symbol. I’m currently using the latest SC (.exe) file. Thanks, |
| [2024-11-22 20:06:52] |
| John - SC Support - Posts: 48583 |
When is it displaying all Long or all Short trades? Is there something you can do to have it showing either all Long or all Short? What are the longer and shorter timeframes you are using where you state that you can see both or not? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-22 21:22:31] |
Please attach the raw Trade Activity Log files to this thread from November 18 through November 21 for the trade account you are viewing. The files are located in the "TradeActivityLogs" folder under you main Sierra Chart installation folder. The filenames have the Date and Account Name in them, so it should be fairly obvious which ones to attach. You can attach the files privately so nobody else can see them. When uploading a file there is an option for "Make Private". Refer to the following: Support Board Posting Information: Attaching a File (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
