Date/Time: Thu, 19 Nov 2026 11:25:27 +0000
Market Depth Window
View Count: 1868
| [2024-11-22 17:10:42] |
| User990339 - Posts: 6 |
Hi. Is there a way to calculate the difference between Ask Orders and Bid Orders? File > Open Market Depth Window > by default it shows the following: Bid Price, Bid Qty, Bid Orders, Ask Price, Ask Qty and Ask Orders as shown in the screenshot below https://prnt.sc/uwWcdpIcbvMS My request is, can SC calculate the difference between Ask Orders and Bid Orders as a percentage? Please advise. Thanks. |
| [2024-11-22 17:19:28] |
| John - SC Support - Posts: 48583 |
There is nothing built into the system that allows for calculating the difference between the Bid and Ask Market Depth data at a specific level. To do this, you would need to create a custom study. Refer to the following: ACSIL Interface Members - Functions: sc.GetAskMarketDepthEntryAtLevel https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php You can view some various information for the total sum of the Bids and Asks by using the "Bid and Ask Depth Bars" study. Refer to the following: Bid & Ask Depth Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
