Date/Time: Thu, 19 Nov 2026 11:25:09 +0000
KTH25 - gives me a blank screen
View Count: 545
| [2024-11-22 17:01:30] |
| DonM - Posts: 4 |
Hi - I"ve had this problem before and never found a solution. No doubt it is something obvious. The screen is black/blank and I can't even right click it (no response). I have tried redownloading the data. I am using a set of copied charts that work fine (it previously had ICEE Coffee) but just not on KT. I believe I have the correct data feeds. https://www.sierrachart.com/image.php?Image=1732252570498.png Any ideas? D Date Time Of Last Edit: 2024-11-22 17:01:43
| [2024-11-22 19:28:32] |
| John - SC Support - Posts: 48583 |
There is no trading for that product. So what you are seeing (nothing) is correct. Refer to the following: https://www.cmegroup.com/markets/agriculture/lumber-and-softs/coffee.quotes.html For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
