Date/Time: Thu, 19 Nov 2026 11:25:24 +0000
Sierra chart installation on a new laptop
View Count: 673
[2024-11-22 15:12:30]
Dsantosjr6 - Posts: 6
Hello, I am trying to transfer my sierra chart to a new laptop, I followed the instructions, copied/ pasted files onto new laptop, when I click the file tap I see my chart books in the dropdown menu but when I click to open the message log says ‘chart book not found’
[2024-11-22 15:37:28]
When you create a new installation you can not use the "Recent Files" list, as those are referencing a path to where the files were on the old computer, which may not be where they are on the current computer. Clear the Recent Files list (File >> Clear Recent Files List) and then open your chartbooks from "File >> Open Chartbook" to start. You can then use the Recent Files list from that point on, as they are now referencing the new path.
[2024-11-23 10:33:43]
OK, I cleared the recent file list, but when I go to "open chartbook" only the example chartbook is there. I don't see my chartbooks
[2024-11-23 15:07:56]
Refer to this help topic:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Make sure you copy your Chartbook files.
[2024-11-24 10:47:30]
I followed those instructions, when I go into my files on my computer I believe I can see my chartbooks, they are labeled with .cht, correct?
[2024-11-24 13:09:09]
Yes those are the Chartbook files.
[2024-11-24 13:29:40]
I see now, they weren’t in the data folder, I copied and pasted them in there, all good now
Thank you
