Date/Time: Thu, 19 Nov 2026 11:25:05 +0000
[Programming Help] - [ACSIL] - 3rd Party libs
View Count: 1794
[2024-11-22 13:43:12]
backinblack - Posts: 43
I am looking to use Boost and a few other 3rd Party libs. Whats the best way/path to put them so they are found by the ACSIL study compiler and the SC run time please?
Thank you!
[2024-11-22 15:33:23]
To do this, you can not use the remote compiler, you need to use a local compiler. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php#BuildingLocallyToDebug
[2024-11-22 16:52:51]
Thanks John. I compile locally. Where do I copy the .h or the 3rd party binaries with in SierraChart folder structure please?
[2024-11-22 19:26:07]
We can not answer that. That is what you need to figure out with your local build.
[2024-11-22 19:49:35]
ForgivingComputers.com - Posts: 1253
Put the *.h and *.cpp in you ACS_Source folder. DLL's go in the Data folder.
