Date/Time: Thu, 19 Nov 2026 11:17:08 +0000
Chart Sharing Frequently Generating Message Logs
View Count: 534
[2024-11-22 12:56:18]
TraderBiku - Posts: 41
I recently discovered the "share chartbook" feature which is a great addition to the program - I noticed however that it generates a huge amount of messages in the message log, some of which seem vaguely like errors, but otherwise just a lot of data refreshing which seems to "ping" the message log every time it does a search for updates - is there a way to suppress this behavior?
I've attached a screengrab of the message log below as an example -
Thank you -
imageScreenshot 2024-11-22 at 1.54.46 PM.png / V - Attached On 2024-11-22 12:55:32 UTC - Size: 93.11 KB - 272 views
[2024-11-26 20:15:45]
We will review these messages. And see what can be removed.
However, you can prevent them from being added. Global Settings >> Message Categories you can uncheck the Chartbook sharing messages.
[2024-11-28 23:56:41]
In the next release these messages will be greatly reduced.
