Date/Time: Thu, 19 Nov 2026 11:25:18 +0000
Auto Rollover
View Count: 803
| [2024-11-19 22:47:11] |
| User841161 - Posts: 357 |
Is there any way to Auto Roll Symbols used in Add Additional Symbol Studies. The only way I have found to roll symbols is to manually change symbols. I didn't know if there is a work around this?
| [2024-11-19 23:44:48] |
| John - SC Support - Posts: 48583 |
If you have the option for "Automatically Rollover Futures Symbol" set to "Yes", then there is not a way to automatically rollover any symbols added to the chart with "Add Additional Symbol" study. But, if you are manually rolling over, by selecting "Chart >> Perform Futures Symbol Rollover", or by selecting the notice that it is time to rollover, then one the window that comes up is an option for "Rollover Add Additional Symbol Studies". Select this option (make sure it has a checkmark) in order to rollover those studies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
