Date/Time: Thu, 19 Nov 2026 11:25:29 +0000
range 3.50
View Count: 467
[2024-11-19 19:12:32]
Gtrader510 - Posts: 76
hi, how can I get 3.50 range chart
image20241119_110739.jpg / V - Attached On 2024-11-19 19:12:17 UTC - Size: 102.34 KB - 212 views
[2024-11-19 23:28:47]
We are not sure what you are trying to show with the image. But refer to the following information and note the references to use the "Range per Bar - True" instead of one of the other Range bar types:
Chart Settings: Range Per Bar - Standard (in ticks) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings >> Bar Period Type)
