Date/Time: Thu, 19 Nov 2026 11:25:11 +0000
Quote Board - Symbols
View Count: 500
| [2024-11-19 17:31:45] |
| User377189 - Posts: 216 |
I see symbols for Nikkei, DAX, Hang Seng etc. But These symbols are not showing the correct data. example: Nikkei is showing -ve (red) for the day but is currently +ve (green). Also Nikkei has so many symbols to select from which how can i tell which one will show current data. Similarly if i want to add other indices which symbols show data?
Private File |
| [2024-11-19 17:35:04] |
| John - SC Support - Posts: 48583 |
You are setup to get real-time data from us for the CME Group. The data for any other symbol is coming from CQG, so you would need to check with them on what is showing for those.
