Date/Time: Thu, 19 Nov 2026 11:25:05 +0000
Gold
View Count: 1295
[2024-11-19 17:17:51]
User756716 - Posts: 32
What is the symbol for Gold for Interactive Broker? The one I am using is not given me any market data.
[2024-11-19 17:27:57]
The only information we will have is what is in the "File >> Find Symbol" window.
What Gold symbol are you looking for? If you are looking for Gold traded on the COMEX exchange, then you should be getting data if you are using the symbol set in Find Symbol (GC-######-COMEX) as you would be getting that data from our Denali Exchange Data Feed.
If you are looking for something else, then you would need to check with Interactive Brokers for the appropriate symbol.
