Date/Time: Wed, 16 Sep 2026 10:51:27 +0000
More symbols through your data feed?
View Count: 1244
| [2014-09-09 00:10:39] |
| ZGerenstein - Posts: 6 |
Hello, I'm wondering if it's possible to get access to more symbols through the free data service you provide when you first sign up? |
| [2014-09-09 01:23:11] |
What specific data service are you referring to. There are several available. And are you talking about a real-time symbol limitation? We are not quite sure. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-10 13:53:20] |
I have SC Forex Data (FXCM)
| [2014-09-10 16:14:18] |
There are no symbol limitations with the SC Forex Data (FXCM) service. Although maybe we are misunderstanding what you are asking about.
| [2014-09-11 14:42:30] |
Well, I don't have access to many of the e-mini products, such as e-mini Dow and S&P
| [2014-09-11 16:31:49] |
Refer to this section here about this: http://www.sierrachart.com/index.php?page=doc/data.php#FuturesData You can use the Sierra Chart Historical Data Service for historical futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
