Date/Time: Thu, 19 Nov 2026 11:43:09 +0000
Data Differences
View Count: 765
| [2024-11-07 19:24:48] |
| User996274 - Posts: 96 |
May be a stupid question: Is there any difference in Data quality between Rithmic and IB, If I subscribe to Package 10, with Denali? thanks |
| [2024-11-07 20:43:55] |
| John - SC Support - Posts: 48583 |
If you are asking if there is a difference in data quality when using the Denali Exchange Data Feed with Rithmic and then with Interactive Brokers, the answer is "no", there is no difference. The data in this case is coming from our Denali Exchange Data Feed and has nothing to do with the connected trading service. If you are asking if there is a difference in quality between Rithmic, Interactive Brokers and Denali - then yes, there is a definite difference in that the Denali data is 100% accurate and has every trade. The same can not be said for the other vendors. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-07 21:15:30] |
I was referring to the the first answer Thanks |
| [2024-11-08 03:43:08] |
| Sierra_Chart Engineering - Posts: 25441 |
Let us know if you have any further questions.
