Date/Time: Thu, 19 Nov 2026 11:43:25 +0000
[Programming Help] - cannot build a custom study
View Count: 2067
[2024-11-07 14:32:24]
jsob - Posts: 46
recently built a new machine and simply 'migrated' partitions over from the old one. Sierra has been working fine. However, today, for the first time, I tried re-compiling my code and have run into an issue (see attached). Thanks
imagecompiler failure.png / V - Attached On 2024-11-07 14:29:13 UTC - Size: 23.94 KB - 275 views
[2024-11-07 16:22:04]
You do not have your Visual C++ Path set correctly on the Build Advanced Custom Studies window. It looks like this is blank.
[2024-11-07 16:56:13]
jsob - Posts: 46
Can you provide me with some guidance? Is there a specific file I am looking for? I'm running Win 11 and I've just installed Visual Studio 2022.
[2024-11-07 20:20:59]
On my Windows 11 system the Visual C++ path is the following:
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\Build
[2024-11-08 11:58:24]
jsob - Posts: 46
by re-installing the Visual Studio suite the path you identified was created on my machine.
I supplied that path and ran the build process.
Still getting an error: "Incorrect path for script file: C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\Build\vcvarsall.bat"
Is this batch file created during the Sierra installation process?
Must I uninstall/reinstall SC to generate it? I'm reluctant to do that as I have so many customizations to my chart display.
Thanks again.
[2024-11-08 12:39:16]
jsob - Posts: 46
same error when I use the path "C:\SierraChart\ACS_Source\" and select VisualCCompile.Bat
[2024-11-08 14:55:30]
jsob - Posts: 46
resolved by installing Microsoft Visual Studio Code then configuring it for Microsoft C++.
Fortunately, found some very useful links
