Date/Time: Thu, 19 Nov 2026 11:43:32 +0000
Excluding TPO/VbP Profiles by Specific RTH and Evening Sessions
View Count: 661
| [2024-11-04 20:25:34] |
| HillCountryTex - Posts: 2 |
Howdy Sierra Support. I'm looking for instructions to see if it's possible to merge specific RTH/Globex profiles on my TPO charts. I've found some instructions, but I'm not quite getting my goal. I'll keep this as efficient as I am able. Goal is to merge profiles by specific date and session. For example: I want to merge a Sunday evening session with a Tuesday RTH profile - and excluding the session in-between. So far, I've found the instructions for "Dates to Exclude." That's excellent and elegant. I'm able to merge individual dates across a chart, and remove the dates I don't want in the merge. That's essentially exactly what I'm looking for. My understanding is that, because of the way evening session time-start is calculated, an excluded date will also exclude the evening session for the prior globex session. Is there a way for me to keep specific evening sessions on the chart, while excluding others the same way I can exclude an RTH date in the standard way? I apologize for the clunky language. I hope this can translate into engineer language. I promise, I've spent a week looking for the answer, I just seem unable to find it. Thank you |
| [2024-11-05 16:24:53] |
| John - SC Support - Posts: 48583 |
There is not a way to do what you are wanting. As you have found, if you exclude a specific date from a chart, you are removing the entire "Trading Day" for that date, so it will remove the Evening Session from the prior date.
| [2024-11-08 12:19:15] |
Thanks John. I wish there were a way to right-click and "hide" an individual profile, but I certainly understand. I'll work with what I have. Thanks again for letting me know!
