Date/Time: Thu, 19 Nov 2026 11:43:32 +0000
Transparent draw style changes when window maximized
View Count: 730
[2024-11-04 16:37:42]
User140788 - Posts: 7
Hello again,
I'm seeing another very strange bit of behavior on my charts with a couple of studies using transparent draw styles. For instance, I have the Stochastic-Slow study on my execution chart and I use the transparent fill bottom and top style to create a ribbon look. When the chart is not maximized, this works normally. But when I maximize the chart by double clicking on the chart tab, instead of being gray, it turns black. When I click restore to return the chart to a smaller size, it goes back to being gray as intended. A couple of images showing the issue are attached.
Thanks so much for your help,
Matt
image2024-11-04 10_34_27-.png / V - Attached On 2024-11-04 16:37:01 UTC - Size: 150.06 KB - 194 views
image2024-11-04 10_35_34-.png / V - Attached On 2024-11-04 16:37:06 UTC - Size: 228.69 KB - 195 views
[2024-11-04 18:25:50]
We do not know why this is the case. Are you using OpenGL for chart graphics?
Date Time Of Last Edit: 2024-11-04 18:26:02
[2024-11-06 18:19:33]
Yes, I am using OpenGL on an Nvidia graphics card.
[2024-11-06 19:19:32]
Please get us a chart that shows this issue by following these instructions:
[2024-11-07 17:38:56]
Interestingly, the problem has gone away on its own. I'll send a chartbook if it recurs.
Thanks,
Matt
