Date/Time: Thu, 29 Oct 2026 00:26:19 +0000
export tick data
View Count: 1771
| [2014-09-07 13:57:20] |
| jivetrader - Posts: 410 |
http://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html does not seem to address exporting tick by tick data. please advise on how to export intraday tick data. thank you. |
| [2014-09-07 20:43:58] |
When you do export the data it will be tick by tick if you have tick by tick data. The data is exported in the same time unit as it exists in the Intraday data file.
| [2014-09-07 21:36:52] |
thanks, i think i have found what i need here: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php |
