Date/Time: Thu, 19 Nov 2026 12:33:11 +0000
Volume profile width based on absolute volume
View Count: 1106
| [2024-09-22 13:06:56] |
| LongShortz - Posts: 53 |
I would like to request a feature that allows the configuration of multiple time frames within a single profile instance. This would allow for one Width setting. The largest POC would become the reference bar for all other bars to scale to based on absolute volume. In this case, you should never see a weekly volume bar that exceeds the length of a higher time frame profile that would include that week's volume. The way SC currently handles scaling, that is possible. And because of this, the visual reference is skewed. If there is already a way to accomplish this, I have not found it. I tried the 'Volume Bars Length Relative to All Visible Profiles' and that did not fix it. I still have a weekly profile that is larger than a 90 day profile at the same price. In my mind, that should not be possible. They should at least be equivalent. Here is the chart https://www.sierrachart.com/image.php?Image=1727010089663.png In the image, Red = Daily Grey = Weekly Orange = Monthly Green = 90 Day You can see the Grey is larger than the green. I'm thinking there is a good explanation. I just can't find it. |
| [2024-09-23 12:53:28] |
| John - SC Support - Posts: 48583 |
There is not a way to do what you are wanting using the current tools. The Input for "Volume Bars Length Relative to All Visible Profiles" only applies to a single instance of the Volume by Price study. What you are wanting is a Feature Request. We take all requests, but we can not say when we would get to any particular item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-24 14:41:41] |
Totally fair. Thanks for the response!
