Date/Time: Thu, 19 Nov 2026 12:57:13 +0000
Remote Build issues
View Count: 1356
[2024-09-10 14:21:43]
User371315 - Posts: 10
The remote build servers appear to be broken.
I'm currently getting error
JSON parse error: The document is empty
[2024-09-10 14:26:02]
We apologize for this. We are checking on this.
[2024-09-10 14:31:04]
FYI Its working now, last night build.sierrachart.com and build2.sierrachart.com was showing the JSON error.
[2024-09-10 14:47:57]
Tony - Posts: 733
@User371315
btw, you could build locally by installing MicroSoft's free Visual Studio Community Version, without even knowing how to use that program.
In Sierra: Build --> Build with Visual C++ (instead of Remote Build)
[2024-09-10 14:51:00]
I started building locally but I have some weird bug right now where when I build locally it crashes on my signals and works in remote build so I'm using that to figure out where the bug is.
[2024-09-10 16:06:33]
Sierra Chart - Max - Posts: 5986
Are you still seeing issues with the remote building? Or has that been resolved?
Sierra Chart Support
[2024-09-10 16:22:48]
The issue is resolved! Thank you!
