Date/Time: Thu, 19 Nov 2026 12:57:28 +0000
Cannot add more than 1 micro contract
View Count: 834
| [2024-09-10 00:56:20] |
| L2Ltrades - Posts: 65 |
Hello, I am using Teton and have enough balance in my AMP futures account to trade up to 5 mnq contracts. But the DOM does not let me open more than 1 contract. Is this an issue with Teton or AMP? |
| [2024-09-10 11:17:29] |
| Sierra_Chart Engineering - Posts: 25441 |
You need to check with your broker on this. Although check the Trade >> Trade Service Log, and let us know what is the rejection message you are getting. There may be something configured on the Sierra Chart side limiting this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-10 11:18:07
| [2024-09-10 11:42:55] |
So on checking the trader service log, it says margins were insufficient. But AMP futures did not raise the margins. They do it usually before a new or data release which is not the case as of now.
| [2024-09-10 13:10:34] |
You will need to contact your broker for help with margins. Show them the exact message you are receiving.
