Date/Time: Thu, 19 Nov 2026 12:57:29 +0000
Question
View Count: 527
| [2024-09-09 20:39:00] |
| User773567 - Posts: 1 |
Hello, I need your help. How can I get these two studies to be locked in one chart? Also, how do I put them on DARK MODE! [image: image.png] Also, I use TradingView and my broker is IBKR. As soon as I connect my TV to IBKR, it kicks out Sierra Charts. Its very frustrating. Can you please help me? I have had sierra for few months but its so hard for me to figure it out. I want to use footprint chart with DOM so I can see orderflow and price action. Please advise or send me some videos that can help me set these two studies up on same chart. Thank you |
| [2024-09-09 20:42:48] |
| John - SC Support - Posts: 48583 |
We are not understanding the question in terms of "How can I get these two studies to be locked in one chart?" In the image, you show a Numbers Bars Chart with the Numbers Bars Calculated Values study on the same chart along with a Volume by Price study to the side. So you have 3 studies on the same chart. We would need more information on what exactly you are wanting. We do not have a specific "Dark Mode". You need to adjust the colors the way you want them for each item. Refer to the following: Graphics Settings As to TradingView disconnecting Sierra Chart, this sounds like they use the same mechanism to connect to Interactive Brokers. If this is the case, then there is nothing we can do. This would be a limitation on the part of how Interactive Brokers connects. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
