Date/Time: Thu, 19 Nov 2026 12:57:30 +0000
Volume At Price Treshold Alert V2 on the DOM
View Count: 648
| [2024-09-08 14:31:50] |
| Eranox - Posts: 41 |
Hi, I have tried to add the study Volume At Price Treshold Alert V2 on the DOM but it doesn't work because nothing is displayed. I have setted everything as for the chart (where it works fine) but on DOM it doesn't work. can you help me? |
| [2024-09-09 14:22:31] |
| John - SC Support - Posts: 48583 |
That study will not work on a Trading DOM as it is trying to place the results next to a bar, which do not exist on a Trading DOM. What exactly are you trying to do? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-09 15:08:40] |
I'm trying to plot and highlight the imbalances on the dom..
| [2024-09-09 18:22:39] |
You can not do this, the Trading DOM does not have a concept of Bars like a Chart does. You would need to do this on a Chart.
| [2024-09-09 22:24:51] |
Is it not possible to highlight the imbalances as they form in the recent trades and current trades columns either? This would be perfect for me highlighting them using text/bars coloring.
Date Time Of Last Edit: 2024-09-09 22:42:18
| [2024-09-09 23:05:32] |
There is no way to highlight the imbalances in the Recent or Current trades columns.
