Date/Time: Thu, 19 Nov 2026 12:57:36 +0000
Trade window is not showing my trades
View Count: 783
[2024-09-06 23:43:09]
User756716 - Posts: 32
I'm using Interactive broker with Sierra Chart via the API. This morning when I executed a trade from SC the trade went through but when I flatten the trade from SC it was still active on Interactive broker. My trade window is not showing the trade nor is the trade activity log shows when I exit the trade. See attached log file and screen shot. I had to call IB to exit the trade because SC wasn't showing that I was in a trade. Why is my trades not being shown in the trade window or why it didn't cancel when I put in the order?
imageScreenshot 2024-09-06 103758.png / V - Attached On 2024-09-06 23:42:54 UTC - Size: 59.18 KB - 263 views
imageScreenshot 2024-09-06 104824.png / V - Attached On 2024-09-06 23:43:03 UTC - Size: 138.59 KB - 262 views
[2024-09-09 13:44:32]
The problem is you are not using the right symbol. The correct symbol for MES is in File >> Find Symbol. Correct all (very important) instances of MES in that instance of Sierra Chart. The correct symbol, follows a pattern like this:
MES-######-CME-USD
Also for CME group trading we recommend using Teton order routing:
Date Time Of Last Edit: 2024-09-09 13:45:00
