Date/Time: Thu, 19 Nov 2026 12:57:19 +0000
Custom value above bar
View Count: 519
| [2024-09-05 12:59:46] |
| YAG86 - Posts: 12 |
Hi SC team, Could you please let me know how I can create the below: I have under every bar the difference between High and Low. I'd like to show above the bar a value that is for example: =200/2/(High-Low) 200 would be my risk 2 would be dollar value for every MNQ point High-Low would be just that the bar range and the result would be my position size. Essentially I'm trying to show above every bar the position size for a trade that is risking one specific bar range |
| Attachment Deleted. |
| [2024-09-05 15:18:23] |
| John - SC Support - Posts: 48583 |
First, you need to calculate the value somehow. The easiest way is to use the Spreadsheet Formula. Refer to the following: Spreadsheet Formula From there, you would use the "Study Subgraph Above/Below Bar as Text" study. Refer to the following: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
