Date/Time: Thu, 19 Nov 2026 12:57:13 +0000
Alerts based on drawings
View Count: 575
| [2024-09-05 01:47:39] |
| User781731 - Posts: 74 |
Is it possible to create 2 alerts for the same drawing e.g. horizontal line? Is it possible to create a drawing alert based on a condition i.e. formula, like you can with studies, rather than the limited options found in drawing properties menu? |
| [2024-09-05 13:48:51] |
| John - SC Support - Posts: 48583 |
Yes, but to do this you need to use a simple alert somewhere in addition to the actual drawing alert. See below. Is it possible to create a drawing alert based on a condition i.e. formula, like you can with studies, rather than the limited options found in drawing properties menu?
Refer to the following for how to reference drawings in alerts: Study/Chart Alerts And Scanning: Referencing Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
