Date/Time: Thu, 19 Nov 2026 12:59:46 +0000
6J - NOT ABLE TO BUY/ SELL -
View Count: 478
| [2024-09-04 13:53:55] |
| User817391 - Posts: 1 |
can not make an order on 6J. Change the seeting to active on "use as trade only symbol". Still cant enter position. Please help.
| [2024-09-04 16:56:02] |
| Sierra_Chart Engineering - Posts: 25441 |
First we want you to update Sierra Chart to the current version: Software Download: Fast Update This is not relevant to the issue but we see you are running an older version. If you are using the Trade and Current Quote Symbol setting, then refer to: Sierra Chart Teton Futures Order Routing: Using Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
