Date/Time: Thu, 19 Nov 2026 12:57:27 +0000
SC is disconnecting during Trading
View Count: 472
[2024-09-04 06:58:27]
User122704 - Posts: 15
I am Sending Message Log via message log "Send for Analysis". SC disconnected for the first time in the middle of a trade and took quite a while to reconnect. Had to reboot computer and SC and that did not solve issue. After about 20 min it connected on its own again. I did try to go File -> Disconnect--> Reconnect and nothing worked. I am unclear on why this is happening.
[2024-09-04 20:15:16]
You have the following error in your log:
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
You had a connectivity issue at that time. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
