Date/Time: Thu, 19 Nov 2026 12:59:42 +0000
Keyboard Shortcut: Days to Load
View Count: 475
| [2024-09-03 18:20:27] |
| User688525 - Posts: 403 |
Hello Sierra, Is it possible to assign a keyboard shortcut to the "Days to Load" instead of creating a custom study using "sc.DaysToLoadInChart"? This would be similar to changing the bar period from 5m to 15m using the keyboard. For example, just as pressing "5 + Enter" changes the bar period to 5 days, pressing "5 + d + Enter" would change the days to load to 5. Thank you Date Time Of Last Edit: 2024-09-03 18:22:21
| [2024-09-04 17:40:35] |
| Cesium - Posts: 179 |
5d+enter typed into the sc buffer would change bar period to 5 days per bar Changing Chart Bars Period: Fast Changing by Keyboard And keyboard shortcuts dont support changing days loaded, closest thing would be assigning a keyboard shortcut to open Chart Settings (Chart>>chart settings) |
| [2024-09-04 18:13:31] |
Hi cesium, Thanks for confirming and the Chart Settings shortcut suggestion. |
