Date/Time: Thu, 19 Nov 2026 12:57:22 +0000
Duplicate Sierra on Laptop
View Count: 541
[2024-09-03 17:15:25]
User852542 - Posts: 2
Hi, I want to duplicate my Sierra Charts over to a laptop. No need for use at the same time, just need the laptop for travel. What is the best way to accomplish this? Thanks, Keith
[2024-09-04 19:39:27]
Refer to the following instructions. The exact option you use to do the copy/installation is up to you:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
[2024-09-05 13:16:04]
My original install has all of the files in a subfolder named: SierraChartTransActMA. Do I need to transfer this folder to the laptop also to insure access to my IronBeam account? Of course, TransAct goes back to Infinity Futures, which no longer exists. Please advise if I need to transfer additional files, and create the subfolder on the laptop installation.
[2024-09-05 15:29:00]
You do not need to replicate the exact folder layout. So you do not need the "SierraChartTransActMA" folder in the new installation. But you will want to transfer the files from the "SierraChartTransActMA" folder to whatever folder you use on the new computer following the appropriate instructions from the page we linked previously.
