Date/Time: Thu, 19 Nov 2026 12:57:31 +0000
Sierra Chart won't save/keep a setting
View Count: 643
| [2024-09-03 17:06:22] |
| pinetrades - Posts: 19 |
There is currently an option under "Chart Trade Settings" that allows you to change the order quantity of a limit order on the DOM. The setting is called "Allow Order Quantity on Order Line To Be Changeable" No matter what I do, this setting always reverts back to "Yes" after I close Sierra Chart. I tried setting it in the global settings, the specific chart, the dom, I use "save all", but the setting won't keep. If I close Sierra Chart and open it up again, the setting will be set to "Yes". I do not want to be able to change the quantity from the chart/DOM, and I like this setting a lot, but it will not remember it. |
| [2024-09-04 19:33:42] |
| John - SC Support - Posts: 48583 |
We will take care of this.
| [2024-09-05 13:24:52] |
| Sierra_Chart Engineering - Posts: 25441 |
We will solve this.
