Date/Time: Thu, 19 Nov 2026 12:57:36 +0000
Line drawings type price
View Count: 474
[2024-09-03 13:43:32]
User436410 - Posts: 5
Hi
I have a horizontal line/drawing on my chart, is it possible to just click/select it and straight away type in the price you want it at. That would really speed tings up
Thx
Alex
[2024-09-04 19:00:41]
You can type in a specific value for a Horizontal Line by adjusting the Anchor point. But there is not a quick way to get to it. You need to right-click on the drawing and select "Chart Drawing Properties" then select the "Anchor" page and change the value in that section.
