Date/Time: Thu, 19 Nov 2026 12:57:37 +0000
How is member m_RotationFactor, returned by sc.GetStudyProfileInformation, calculated?
View Count: 599
| [2024-09-03 01:56:17] |
| Mark Lewis - Posts: 27 |
Most of the members of n_ACSIL::s_StudyProfileInformation are self-explanatory. However, I'm unsure what m_RotationFactor represents or how it might be calculated. Can you provide some more information on this member? It may be useful for an idea I want to implement in a custom study. Thanks! |
| [2024-09-04 18:55:36] |
| John - SC Support - Posts: 48583 |
The value is the Rotation Factor that is associated with the TPO profile. The general definition of the Rotation Factor calculations in Sierra Chart can be found here: Rotation Factor You would then need to apply the logic given above to each sub-period in a TPO in relation to the previous sub-period. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
