Date/Time: Thu, 19 Nov 2026 12:59:52 +0000
Accumulative volume delta
View Count: 451
[2024-09-02 21:07:05]
Silong - Posts: 5
Hi Sierra,
can you check why when i put Accumulative volume delta, candle stick is not fully show?
refer to attached below:
thank
imageScreenshot 2024-09-01 093726.jpg / V - Attached On 2024-09-02 21:07:01 UTC - Size: 369.51 KB - 230 views
[2024-09-04 18:20:09]
If you are referring to the "gap" that occurs each day, it is because that study is set to restart each day, so it will start at 0 at the beginning of the trading session as set by your Session Times.
