Date/Time: Thu, 19 Nov 2026 13:09:33 +0000
%ratio of delta volume with the total volume of each bar
View Count: 763
[2024-08-30 17:58:51]
User445548 - Posts: 1
To whom it may concern,
using the Volume by price indicator, on the attached file you can see that at each volume profile bar there is a delta number of that volume bar on the left and total volume of that volume bar on the right. I tried so many times to get the % ratio of the delta volume with the total volume for each volume profile bar. Is there a way I can do that or, is there a ready-to-use study in the library?
Regards. Ali.
imageEkran Resmi 2024-08-30 16.15.43.png / V - Attached On 2024-08-30 17:58:47 UTC - Size: 195.88 KB - 326 views
[2024-08-30 18:01:12]
The options for what can be displayed in the bars is defined at the following link:
Volume By Price Study: Display Volume in Bars
If what you are looking for is not in the list, then there is not a way to display it.
