Date/Time: Thu, 19 Nov 2026 13:09:29 +0000
3-month SOFR on Rithmic with Denali
View Count: 565
| [2024-08-30 12:58:13] |
| User282741 - Posts: 38 |
Hi. I'm using Denali datafeed with Rithmic Direct. I can't find 3-month SOFR futures under Symbol -> CME. What should I do to have them? If it's something on your end, please enable it. |
| [2024-08-30 13:16:54] |
I've been trying to manually enter SR3Z4.CME symbol, and adjust tick size, etc., but I get an empty DOM.
| [2024-08-30 15:23:50] |
| Sierra_Chart Engineering - Posts: 25441 |
You cannot manually specify a symbol when using Rithmic. You will not receive market data. We will not be doing any further symbol updates for Rithmic. You need to use either Teton order routing (preferred) for the symbol or if you want you can use CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
