Date/Time: Thu, 19 Nov 2026 13:09:40 +0000
[User Discussion] - Timer range highlight, transparent study
View Count: 595
[2024-08-30 04:54:46]
RedFNbuLLz - Posts: 3
I've been using this indicator for a while now. today it has not been working. I tried to remove the study, add the study, remove the study. reboot Sierra chart and still nothing. Is there currently a bug with the Study. I use it with A TPO lay out just for some information on my charts. ps. tried using both Time range and Time range transparent. can't get them to work all of the sudden. (Never had issues with the study before.)
[2024-08-30 15:29:44]
If this was working previously on a TPO chart, then that was just luck that it worked at all. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
If you are having a problem with this study on a non-TPO chart, then let us know.
