Date/Time: Thu, 19 Nov 2026 13:09:41 +0000
ATR
View Count: 718
| [2024-08-30 02:05:34] |
| Ghosttrader - Posts: 40 |
Hello, I'm trying to configure a ATR based on 5 min time frame with a look back of 4 periods. I want to display it as a value on the chart. How would this be possible using the ATR within the studies of SC? thank you. |
| [2024-08-30 14:27:12] |
| John - SC Support - Posts: 48583 |
What do you mean by "4 periods"? Is this 4 bars, 4 trading days, 4 day sessions, 4 evening sessions, ...?
| [2024-08-30 16:56:48] |
4 bars. So based on whatever time frame i'm looking at the 5, 15 etc. The look back will be 4 bars. If a 5 minute chart then the 4 previous bars.
| [2024-08-30 18:16:02] |
The "Average True Range" study has a "Length" option that gives you the average ATR over that many bars. So you would want to set this to a value of 4. Refer to the following: Average True Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
