Date/Time: Thu, 19 Nov 2026 13:09:34 +0000
How to Recompile Custom Study .dll?
View Count: 1854
| [2024-08-29 21:21:23] |
| john4th - Posts: 35 |
Hi, How do I fix this? In the Add Custom Studies > underneath SC Custom Studies is a message D:\SierraChart\Data\scsf_TDSetup.dll needs to be recompiled to be used on this version 2671. Thanks |
| [2024-08-29 22:50:21] |
| Mark Lewis - Posts: 27 |
You just need to use Analysis > Build Custom Studies DLL. Start at step 9 here: How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions |
| [2024-08-30 00:40:12] |
| ForgivingComputers.com - Posts: 1253 |
This assumes you have the source code (.cpp file): You just need to use Analysis > Build Custom Studies DLL.
If you don't then I suggest you contact the developer. |
| [2024-08-30 01:01:55] |
Indeed. Thanks for catching my assumption. You can try looking here for the file: /SierraChart/ACS_Source/scsf_TDSetup.cpp depending on where you have Sierra Chart installed. |
