Date/Time: Thu, 19 Nov 2026 13:09:32 +0000
Alerts - Cannot Silence
View Count: 548
| [2024-08-29 20:12:35] |
| User630447 - Posts: 10 |
For the life of me - I cannot silence the Alerts. I have turned them off globally and they still go off. I have gone through all the individual alerts and I still cannot get them to silence. Then, I run a replay and I get 50 bells going off until it's done. Isn't there supposed to be an easy way to silence everything?? I thoughts that's what the global alert settings did. Thank you. |
| [2024-08-30 13:56:07] |
| John - SC Support - Posts: 48583 |
To stop the playing of alert sounds enable the option for "Global Settings >> Mute All Alert Sounds". Refer to the following: Global Settings Menu: Mute All Alert Sounds (Global Settings menu) But, in order to actually make an individual alert not have a sound, you need to remove the Alert Number that is assigned for that alert. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
