Date/Time: Thu, 19 Nov 2026 11:17:04 +0000
Edit Custom Symbol Ratio
View Count: 671
| [2024-08-29 19:58:08] |
| User116561 - Posts: 16 |
Hi, Is there a way to edit a Custom Symbol after it's created? For example, if I navigate to Global Settings -> Symbol Settings, find a custom symbol I have already created - is it possible to edit the ratio I used for the symbol without having to create a new symbol? Thanks. |
| [2024-08-30 13:45:14] |
| John - SC Support - Posts: 48583 |
There is not a way to edit the symbol. You need to duplicate the symbol and create a new one with the new name setup the way you want it. Refer to the instructions here: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-30 15:11:44] |
Thanks, that is what I've been doing, and it is a slow process when one has multiple custom spreads. Is there any possibility this could be changed in the future?
| [2024-08-30 16:35:15] |
We take all requests, but we can not say when we will get to any particular item.
| [2024-08-30 16:49:36] |
That's fair, thanks for the consideration. I will assume this request has been recognized, thanks again.
| [2024-12-06 21:31:57] |
| Sierra_Chart Engineering - Posts: 25441 |
Yes you can edit this symbol, but you have to exit from Sierra Chart, and edit the XML file: Global Symbol Settings: Direct Editing of Global Symbol Settings through Underlying File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-07 14:41:06] |
Thanks, this was very helpful and I was able to edit custom symbols using the XML files. Is there a way that the new, edited symbol can flow into a chartbook without having to create a new chart? For example, I have the chart of a custom symbol in a chartbook. Exit Sierra Chart and follow the instructions to update the XML file. Re-open Sierra Chart chart and the new custom symbol data is loaded into the chart? I tried this and it was the old symbol... |
| [2024-12-09 15:45:41] |
There is no connection between the edited symbol settings and the symbol of the chart. Therefore, you have to re-select the symbol for the chart after you have changed the symbol settings.
| [2024-12-09 15:56:01] |
Thanks for clarifying John.
