Date/Time: Thu, 19 Nov 2026 12:59:50 +0000
Bis/Ask stack/pull
View Count: 1399
[2024-08-29 17:42:28]
VolTrader73 - Posts: 139
Hello.
Im trying to control the amount of b/a s/p for individual charts.
Under chart settings /market depth I thought that the input for "number of levels for b/a calculation" would control also the calculation for the number of price levels of stack/pull.
This is not the case and using the trade/chart dome settings affects Globally all charts for which I want to use s/p calculations
How to I set up (for example) 40 s/p levels for ES-future chart and only 27 for NQ-future chart ?
Pls advise
[2024-08-29 17:54:39]
There is no support for this. The only option for controlling the number of Pulling/Stacking levels is the global setting for "Trade >> Chart DOM Settings >> Other >> Maximum Bid Ask Market Depth Pulling Stacking Levels". Refer to the following:
Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
[2024-08-30 12:21:22]
Ok so we cant control separately the individual number of price levels for s/p for individual charts.
Other question, :
Can the s/p data be re-seted/cleared every X time other than manually doing so over each individual symbol dome ? like the attached screen ?
I have 20 symbols I work with and doing this 20 times every Xminutes is not so productive
Date Time Of Last Edit: 2024-08-30 12:22:23
imageS-P reset.png / V - Attached On 2024-08-30 12:20:49 UTC - Size: 67.04 KB - 242 views
[2024-08-30 16:08:34]
There is not a way to reset the Pulling/Stacking at a set time interval. Just the option to clear it on the right-click in the DOM.
You could create a custom study to do this. There is a function named sc.ClearMarketDepthPullingStackingData() to do this. It is not yet documented, but you can find the format for it in the Sierrachart.h file in your ACS_Source folder. Refer to the following:
How to Build an Advanced Custom Study from Source Code
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2024-09-01 13:02:06]
Does this mean a button on the top SC window frame that would clear ALL at once or do I still need to go one chart/dom at a time ?
If that function can re-set all dom/charts for the s/p data, please provide the script and how to set up the button on the top of SC window, as I dont know how and have no intention to learn scripting this for this basic function.
[2024-09-04 14:33:06]
If you do not want to learn how to program then you can pay someone to do this for you. Refer to the following (which we had linked above as well):
