Date/Time: Thu, 19 Nov 2026 13:09:40 +0000
Matching price scale across different time frame charts
View Count: 519
| [2024-08-29 12:47:59] |
| L2Ltrades - Posts: 65 |
Hello, Is there a way to have the same timescale plot automatically across multiple charts on different timeframes setup in a grid like fashion. For example if I have a 1 minute chart and a 1 hour chart next to each other, the price scale has the same range so whatever goes on inside the high and low of the 1 hour candle can be seen on the 1 min timeframe without having to constantly zooming in and out. Trying to plot 1 hour candles and corresponding 1 min candles side by side by in the same top and bottom range. Thank you, |
| [2024-08-29 14:40:00] |
| John - SC Support - Posts: 48583 |
There is not a way to make this occur automatically. You would have to adjust the scales to get them to align as best you can. Or, you can setup one chart, making sure to have the Scale set to a "Constant Range" and then duplicate that chart and change the Bar Period.
