Date/Time: Thu, 19 Nov 2026 13:09:33 +0000
[Programming Help] - Programming Help: Tick Size and Scale Range Type
View Count: 966
[2024-08-29 09:45:37]
User688525 - Posts: 403
Hello Sierra Chart,
I have created a simple custom study to change the Tick Size and Scale Range Type using the code below.
Can assistance please be provided for two issues:
1) The ScaleConstRange is not being applied to the main graph ("0"). If this is changed to "1" (graph 2), then it appears to work?
2) When sc.FlagToReloadChartData is set to "1", the chart continuously reloads/loops?
#include "sierrachart.h"
SCDLLName("Ticks Range")
SCSFExport scsf_TicksRange(SCStudyInterfaceRef sc)
sc.TickSize = 0.5; // Set the tick size to 0.5
sc.ScaleRangeType = SCALE_CONSTANT_RANGE; // Set this study to use a centered constant range scale
sc.ScaleConstRange = 30; // Set the range of the scale to 30 points
sc.GraphRegion = 0; // Use the main price graph region
sc.FlagToReloadChartData = 1; // Reload the chart data
Thank you
[2024-08-29 12:22:17]
emmanuel - Posts: 63
Try this:
int& IsTickSizeSet = sc.GetPersistentInt(0);
if(sc.SetDefaults) {
if(sc.Index == 0 && IsTickSizeSet == 0) {
IsTickSizeSet = 1;
[2024-08-29 19:20:46]
Hello emmanuel ,
Thanks for your help.
When I build and run the study, no errors appear, however, neither the scale or ticksize change?
Update: the following code changes the tick size but not the scale range:
int& IsTickSizeSet = sc.GetPersistentInt(0); // track if tick size has been set
// Set chart properties
sc.ScaleRangeType = SCALE_CONSTANT_RANGE; // set scale range type to constant range
sc.ScaleConstRange = 30; // set constant range value to 30
sc.GraphRegion = 0; // set study Graph Name
return;
// Check and set tick size
if(sc.Index == 0) { // check tick size
if(sc.TickSize != 0.5) { // if tick size is not 0.5
sc.TickSize = 0.5; // set tick size to 0.5
IsTickSizeSet = 1; // mark that tick size has been set
sc.FlagToReloadChartData = 1; // reload chart
Date Time Of Last Edit: 2024-08-29 19:33:30
[2024-08-29 19:36:44]
OK, then you can apply the same concept to the scale range. When the sc.Index is 0:
1. Check if the scale range type is correct, if not, set it.
2. Same for the scale range.
Note: You can remove the IsTickSizeSet stuff since the comparison you're doing to 0.5 is effectively doing the same thing.
[2024-08-29 22:00:19]
Thanks for the suggestions. I will make a few changes and see if this works.
[2024-08-30 08:05:10]
User431178 - Posts: 910
For setting the main graph to a specific constant range, did you try these?
ACSIL Interface Members - Variables and Arrays: sc.BaseGraphScaleRangeType
ACSIL Interface Members - Variables and Arrays: sc.BaseGraphScaleConstRange
[2024-08-30 09:30:02]
Thanks for the help and the links.
Yes, I did and have now managed to get the study working. I was using "sc.ScaleConstRange" instead of "sc.BaseGraphScaleConstRange".
Thanks again!
