Date/Time: Thu, 19 Nov 2026 12:57:26 +0000
CFE feed VIX down?
View Count: 622
| [2024-08-27 13:38:51] |
| user_xyz - Posts: 529 |
Is the CFE vix feed down I'm not getting any udpates
| [2024-08-27 16:11:33] |
| John - SC Support - Posts: 48583 |
We are not seeing any issues. Keep in mind you will only see updates every 15 seconds.
| [2024-08-27 16:19:22] |
| Sierra_Chart Engineering - Posts: 25441 |
You need to update Sierra Chart to the latest version. Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-28 00:16:38] |
I was on v2669 but updated to v2670. Also rebooted for good measure It still appears data is lagging by 5 min or more? |
| [2024-08-28 01:50:43] |
The issue with the CFE feed is now resolved. This is a recent issue.
| [2024-09-05 00:13:45] |
Since you all brought the CFE back online the Change % are way out of whack. Any chance you guys can check on this. Thanks
| [2024-09-05 13:41:40] |
Where are you viewing the Change % and what exactly is it showing? If you can give us an image, it would be helpful.
| [2024-09-05 14:17:29] |
This will be resolved.
