Date/Time: Thu, 19 Nov 2026 13:09:25 +0000
How to get access to the Sierra Chart WebAPI?
View Count: 1846
[2024-08-23 15:00:52]
PS2004 - Posts: 49
Hello!
I have a website and I want to make calls to the Sierra Chart WebAPI, but the response is "{ ERROR: 'ACCESS_DENIED' }".
I DO NOT want to ask for programming help, hence you explicitly said here that you do not provide help in this field: API connection question
My question is, how to achieve this:
AdminUsername: This must be set to your Sierra Chart Account Name which has been authorized access to this API.
, here is the link: https://www.sierrachart.com/index.php?page=doc/WebAPI.php#GetListOfSierraChartAccounts_Specifications.
Thank you so much in advance,
Sandor
[2024-08-23 15:24:46]
This particular API is discontinued. Some affiliates used it in the past, but it is no longer offered. We will remove it from the documentation now.
Date Time Of Last Edit: 2024-08-23 15:25:00
[2024-08-23 15:29:10]
PS2004 - Posts: 49
Thank you!
My final goal is to hand out Custom Studies to the users of Sierra Chart using the WebAPI.
How can I get authentication for that?
[2024-08-23 15:45:32]
There is a different way this is done. Refer to:
Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users
[2024-08-23 16:05:52]
PS2004 - Posts: 49
There is a text in the page you provided saying:
To control and allow use of your studies/systems by a certain defined list of users, you will need to create a grouping within our web-based control panel for managing custom studies users.
I want to make it dynamic, so I do not have to add every user who registered or subscribed manually.
I want to use this function of the WebAPI: Sierra Chart Website APIs: Manage Custom Studies Users
The bigger picture is: if a payment is successful, I want to automatically allow the users to use the given DLL.
Date Time Of Last Edit: 2024-08-30 18:43:54
[2024-08-30 05:39:17]
PS2004 - Posts: 49
Hi!
Could you please clarify how to dynamically allow users to use a DLL after a successful payment using the WebAPI?
I haven't received a response yet and would appreciate your help.
Best regards,
Sandor
[2024-08-30 13:09:14]
ondafringe - Posts: 343
You should be able to write and host your own Web API for user control, along with a user database, and then add code to your custom study to access your API's end points to dynamically add/control users/access.
Date Time Of Last Edit: 2024-08-30 18:37:50
[2024-08-30 18:38:03]
Regarding post #5 we have to get back to you on this.
[2024-08-30 18:44:49]
You can use this web service API and it is available:
If you get any authorization error let us know, but it should be accessible for you.
Let us know if you need any help with it.
Date Time Of Last Edit: 2024-08-30 18:45:00
