Date/Time: Thu, 19 Nov 2026 13:27:36 +0000
Read Only Session times
View Count: 836
| [2024-08-16 16:23:41] |
| User732858 - Posts: 4 |
Hello, How can I change the session times on my Daily candle charts? The option is grey in the menu selection. Duplicating another chart/making a new chart is still greyed out. It's extremely annoying since the actual D chart looks completely different. Photos attached. thanks. |
| [2024-08-16 18:13:02] |
| Sierra_Chart Engineering - Posts: 25441 |
You cannot change those. Refer to: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
