Date/Time: Thu, 19 Nov 2026 13:27:32 +0000
my trade fills won't work...
View Count: 449
| [2024-08-16 12:48:43] |
| User849502 - Posts: 485 |
Morning Guys, My trade fill window won't fill today's trades. As you see on the screenshot it is set for today, non-sim, fills, and you can see from the dom that I have made a trade. If I put in yesterday's date it works fine. I closed and restarted SC but that did nothing. Any ideas? thanks, Karen |
| [2024-08-16 12:51:26] |
| Sierra_Chart Engineering - Posts: 25441 |
Set the From Date to 2024-08-15. It is reversed relative to the To date.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-16 12:51:40
| [2024-08-16 12:59:58] |
I am an idiot, I must have hit that drop down by mistake. Sorry to bother you. thank you
