Date/Time: Thu, 19 Nov 2026 13:27:33 +0000
HKEX CQG Continuous Futures Contracts
View Count: 571
| [2024-08-16 00:20:39] |
| ivory - Posts: 108 |
Hello, I am using CQG through Amp to access HKEX futures. I noticed that the Continuous Futures Contract functionality does not work. I found a thread from 2021 that suggests using Denali for Historical Data. However, I believe HKEX support has been discontinued since. Is there a way to get it to work? Thanks, I. |
| [2024-08-16 02:06:29] |
| Sierra_Chart Engineering - Posts: 25441 |
Yes, the there is no support for Continuous Futures Contracts through data from CQG. Sierra Chart no longer provides data for this exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
