Date/Time: Thu, 19 Nov 2026 13:27:22 +0000
Order Modification Window - Quantity No Longer Highlighted When Opened
View Count: 543
| [2024-08-15 05:19:00] |
| User924125 - Posts: 14 |
Hi, in the latest Sierra Chart 2667, when I click to modify an order, the number in the quantity field is no longer highlighted as it was in previous versions. Now the cursor blinks before the number. Please see attached screenshots. Is there a way to fix this back so it highlights the number when you open the modify box as it was before. |
| Attachment Deleted. |
| [2024-08-15 23:15:06] |
| Sierra_Chart Engineering - Posts: 25441 |
There is a setting which controls this. It is: Global Settings >> General Settings >> Settings Windows >> Select Text in Edit Control Upon Editing Set this to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-15 23:15:27
